FUEL PUMP FLOW RATE!!
Hi mate i have the cbr 400 rr and i had fuel pump problems and i couldnt find a stock one for my bike so i went out and did some research asked about flow rates and stuff and couldnt find no infomation then i found a cheap cbr 600 fuel pump on a scrap cbr 600 and it looked exactly the same so i took it and tryed it on my cbr the inlet and out let ports on the actualy pump was bigger then myn but i got the pipes on with some perswation and it worked as i found out later on today all honda's use the same fuel pump up to a serton age then they moved them into the fuel tank but if its oldenuf it is still under the seat like the cbr 400 but it should work tho . hope this helps lee.
