fuel injector cleaner/ octane booster
Old Nov 17, 2006 | 10:15 AM
xtremef4i's Avatar
Default fuel injector cleaner/ octane booster
I was wondering if using a fuel injector/fuel system cleaner or an octane booster will harm the bike in amy way. I dont have any problems with it running, I just wondered If it was ok to run it in a bike like you would run in a car.
Old Nov 17, 2006 | 10:44 AM
gixxereater's Avatar
Default RE: fuel injector cleaner/ octane booster
I dont see why not. I used FI cleaner this spring when my bike was having some carb issues from forgetting stabil last year and it worked good.
Old Nov 17, 2006 | 11:41 AM
woodyracing's Avatar
why would you put octane booster in your bike?????????????
Old Nov 17, 2006 | 01:02 PM
Actually running a fuel with ethenol in it will do the same thing to clean out carbs. 89 octane will work, although depending on what bike you have, it may be a bit low.
Old Nov 17, 2006 | 04:01 PM
FATHEADS1KRR's Avatar
I have heard that octain boost can harm the engine, like if you take a whole can and put it in your small m/c tank. Use this stuff spairingly, if at all. If you want a good cleaning and fuel stabilizer, use seafoam. Good stuff.
Old Nov 17, 2006 | 04:11 PM
dragonium25's Avatar
Octane boosters are a waste of money and don't do jack.
Old Nov 17, 2006 | 04:29 PM
Not true. They wont help modern bikes, but older bikes with high compresion and cars with high comp will benefit if you are running too low of octane and need a little help to prevent detonation. 104+ works best for that application.
Old Nov 17, 2006 | 06:12 PM
Jaybird180's Avatar
Someone on here said that he put cleaner in his bike and it ran like crap until it ran through.
Old Nov 18, 2006 | 04:33 AM
JBaz's Avatar
each octane booster can is suppose to be good for a 20 gal tank... So you should use it in that ratio.
Old Nov 18, 2006 | 01:06 PM
900RR Puzzle's Avatar
Anyone have an opinion on what carb/FI cleaner works best on a carburated bike (like my 900RR)?
