Front Brakes 01 929
Sounds like you have some sticky calipers. That's the number 1 killer of disc brakes. I would first take them both off and clean them, lube the cylinder boots and slide points, work them in and out a bunch of times, careful not to damge the cylinder. While your at it I would bleed the front brakes a bunch get some new brake fluid in there. Start there and see if it takes care of the problem.
