fork lock question?
Old Sep 11, 2007 | 12:39 AM
yihaw's Avatar
Default fork lock question?
i just started having this problem. when i turn off my 2002 cbr f4i it wont let me lock the bars to the left. it just wont click into the lock position i have tried to do it with both of my keys. any sug?
Old Sep 11, 2007 | 07:31 AM
EHonda's Avatar
Default RE: fork lock question?
You need to push down on the key and then turn. Also, make sure that you've turned your bars all the way to the left. It should be as easy as that.
Old Sep 12, 2007 | 12:58 AM
zerochickenstrips's Avatar
Sometimes the steering lock (the tab on the frame that keeps you from turning too far) can get worn a bit so you can't turn it all the way to lock it with the ignition. Just move it slightly left to right until the lock cylinder slips into the recess in the frame neck. And like Ehonda said make sure you're pushing the key down as you turn it.
Old Sep 12, 2007 | 02:07 AM
Blue Fox's Avatar
Retired Moderator
If you have the handlebars turned too far (full lock), sometimes it won't lock. Push the key down and try to lock it while trying to wiggle the bars slightly in the full lock position. That's happened to me a couple of times.
Hope that helps.
sboarder1036
Aug 3, 2013 11:49 PM
hopz
Jun 11, 2009 05:21 PM
neely321
Jul 8, 2008 02:57 PM
xcessivemotosports
Mar 21, 2008 07:46 PM
n_vanexel31
Feb 8, 2008 02:37 PM
