fog in headlight
fog in headlight
yes i have some condensation in my assembly. is there any way to get it out? it obviously happened when i was installing angel eyes, and there was this small rubber elbow with some filter sponge looking stuff and i couldnt find its home. maybe thats it, i dont know. any help would be appreciateddddddddddddddddddddddddddddddd
RE: fog in headlight
Your best bet may be to re-remove the housing and make sure it is fully dried (let it sit, or use a hairdryer). Make sure all your contacts where the housing seals are completely clean using alcohol or some safe solvent. You can then apply a think bead of clear windshield silicon sealant around the whole edge where the sealing need to be done. If you get the silicon on well enough, it probably won't show. I haven't done this on a bike, but it solved the problem on my car, and I can't see how they'd be too different. I've also heard of people drilling very small holes at the bottom of their headlight housing to allow the moisture to escape, but all you'd be doing is letting dirt get in there too, so I wouldn't recommend that approach.
papa wheelie
07-20-2011 11:16 AM
Davidth93
07-16-2009 12:22 AM
cyber00677
08-03-2007 03:57 PM
