flywheel puller
Old Jan 31, 2007 | 09:26 PM
Err's Avatar
Err
Default flywheel puller
am i using the flywheel puller right? i have the smaller thread far as it will go into the crank and the larger sleeve on tight. not to sure where to go from here. its a 6 in 1 tool and the bike is a f4i.
Old Jan 31, 2007 | 09:33 PM
13brsxsrr's Avatar
Default RE: flywheel puller
Do you have a dead blow hammer?
Old Jan 31, 2007 | 10:33 PM
Err's Avatar
Err
yes i do. i was thinking if it was a good idea to hit it but wasn't sure which though. do i have the tool set up right?
Old Feb 1, 2007 | 01:21 AM
13brsxsrr's Avatar
Remove the puller and make sure there isn't anything obstructing the shaft. The primary gear should have come out with the clutch basket. You can tap (not pound) on the gear with the dead blow to help loosen it but I'm pretty sure it should have come out with basket.
Old Feb 1, 2007 | 06:36 AM
13brsxsrr's Avatar
ORIGINAL: Err
[sm=oopssign.gif]Nevermind that last post. I'm retarded, working on the wrong side of the bike.
It looks like you have the puller on right. You need to keep the flywheel still with a band(I forget the correct name of the tool)and then loosen the flywheel by hitting the puller with the deadblow.
Sorry about that, it was thesherm talking. By the way when it does come out I think a little metal tab will follow it. Don't loose it will need to go back on shaft as a guide.
Old Feb 1, 2007 | 09:21 AM
Err's Avatar
Err
so put the flywheel holder on and tap the puller going counterclock wise?
Old Feb 1, 2007 | 10:04 AM
Idle Hands's Avatar
dont know how thats gonna work, I use a steering wheel puller. three bolts thread into the flywheel, and a center dowel pushees against the crank, pulls it right off. http://www.amazon.com/exec/obidos/AS...6-20/ref=nosim
Old Feb 1, 2007 | 06:00 PM
Tahoe SC's Avatar
there Err goes breaking his bike again...sigh...
Old Feb 1, 2007 | 06:48 PM
Err's Avatar
Err
ORIGINAL: Tahoe SC
i was waiting for that......
Old Feb 1, 2007 | 06:52 PM
Tahoe SC's Avatar
muahahahhaha...that's right mang!
come over to the kneedragging side...break much less parts than the stunna side.
bratprince
Apr 19, 2012 06:12 PM
Denfrosnesko
Feb 20, 2011 09:46 PM
Winchester
Oct 16, 2007 03:30 PM
