Flasher Relay Location?
Old Aug 23, 2006 | 09:41 PM
redliner25's Avatar
Default Flasher Relay Location?
Hey guys,
I've seen the 1000rr relay is behind the left mid fairing...and it's an easy swap to do.
Does the same follow for a 600rr?
Also, are there multiple relays on the left hand side? How will I know which relay to replace?
I have LED's all around now, and they dont even want to blink anymore its so rapid. Instead of fooling with all the resistors, etc. This is far better choice.
Thanks
Old Aug 23, 2006 | 09:49 PM
redliner25's Avatar
Default RE: Flasher Relay Location?
Now I'm reading that the relay is on the speedo, then I read the relay is between the headlights...?????
I even read you can't get the relay for the 600rr? Is this true? Someone point me in the right direction, please!
Old Aug 23, 2006 | 10:47 PM
DThompson's Avatar
Im pretty sure its in the front fairing. Just go ask a dealer. They will tell you right where it is.
Old Aug 24, 2006 | 08:32 AM
mikequinn's Avatar
you should hear it clicking when you switch the indicator on, or even feel it
Old Aug 25, 2006 | 04:33 PM
christhek's Avatar
Just looked at a friends bike today (1000RR) and the turn signal relay was between the front lights. His was replaced with a trick relay to synchronize the flash and to give it some cool effects.
gissmo50
Feb 15, 2010 08:56 PM
muckdawg24
Sep 17, 2007 12:13 PM
westlakeCBR1KRR
Jun 22, 2007 04:07 AM
turnerrr600
Jun 15, 2007 07:24 AM
stang930
Jul 6, 2006 12:42 AM
