Flasher Relay Location?
Hey guys,
I've seen the 1000rr relay is behind the left mid fairing...and it's an easy swap to do.
Does the same follow for a 600rr?
Also, are there multiple relays on the left hand side? How will I know which relay to replace?
I have LED's all around now, and they dont even want to blink anymore its so rapid. Instead of fooling with all the resistors, etc. This is far better choice.
Thanks
Thanks
Now I'm reading that the relay is on the speedo, then I read the relay is between the headlights...?????
I even read you can't get the relay for the 600rr? Is this true? Someone point me in the right direction, please!
Just looked at a friends bike today (1000RR) and the turn signal relay was between the front lights. His was replaced with a trick relay to synchronize the flash and to give it some cool effects.
muckdawg24
Sep 17, 2007 12:13 PM
