FI Light on after bike is turned off
Hey guys. My buddy and I are trying to figure out a problem with a 2003 CBR F4I. The FI light came on, and it stays lit after I turn the bike off.
If I recall correctly the light wasn't on when I was riding today only when I turned the bike off and it stays solid red when the ignition is off and the keys are out of the ignition. I took the seat off and disconnected the negative on the battery (don't want it to kill my battery). I checked the fuses, and couldn't find any blown fuses...
Anyone run into this before? The speedometer is not working (the digital gauges) - could it have something to do with that?
Any help is greatly appreciated.
might as well. Its the easist way to start looking. Doesnt take too long. I'd start by concentrating around the forks and look to see what wire bundles move when you turn the handlebars left and right. Maybe something slipped and is rubbing the forks or triple tree.
The other thing would be to figure out how to read what the FI code is. Not sure if thats something you can do yourself or if it requires a special tool.
download this, its eh service manual for 01-03. Check around section 5, it explains the FI procedure to look for codes, as well as everything else you might wanna know about the bike.
http://www.stephygee.com/f4imanual.zip
stephygee is awesome.
You mean you dont hear the noise it usually makes? If thats the case, make sure the fuel pump plug isnt loose, thats the loudest part of the FI system.
See if that manual says anything about it as well.
Well here is where I am now.
I have a bike in peices on my garage floor.
The bike will turn over, there is power to all the lights ect.
If I turn on the kill switch I do not hear the fuel pump engage. I checked the connection underneath the fuel tank and the connection looks fine.
I don't know where else to go from here...
