FI light 2001 CBR 600 F4I
Old 03-24-2014, 08:49 PM
MarioDC13's Avatar
New Member
Default FI light 2001 CBR 600 F4I
I recently bought a 01 cbr 600 and the FI light came on today. It doesnt come on right away only after riding it for a while, it really seems to come on when I really lay into the throttle. When I shut the bike off and turn it back on it goes away. How do I read the error code for the FI light and what do the different number codes mean. Also, when the bike is on the kickstand and ignition on the FI light does not come on. Please help.
Old 03-24-2014, 09:32 PM
tamahda's Avatar
Does the light remain on? or does it blink? if the later count how many blinks and the fine fellows on this community will surely help you sort it out.
Old 03-24-2014, 10:20 PM
PossibleOne's Avatar
Welcome Crew Technician
Yes, what tamahda said. Count the blinks, fast blinks and slow blinks or not blinking at all. Report back what you see.
-Poss
Old 03-25-2014, 04:12 PM
MarioDC13's Avatar
New Member
Yea the light doesn't flash at all it only comes on when I'm riding and stays solid until I shut it off thanks for the help so far!
Old 03-25-2014, 04:21 PM
74demon's Avatar
You will need to jump the diagnostic connector under the seat to get it to flash codes.
Old 03-29-2014, 04:18 PM
MarioDC13's Avatar
New Member
Ok guys I got some flashes, one long one short im assuming this is 11 correct? anyone know what code 11 is???
Old 03-30-2014, 09:44 AM
DefconZero's Avatar
A long blink = 10
A short blink = 1
CODES:
0 - bank angle sensor, ECM, PGM-FI fuse
1 - MAP sensor
2 - MAP sensor vacuum hoses, or sensor itself
7 - ECT sensor poorly connected or open circuit
8 - TP sensor, TP senspr wiring
9 - IAT sensor connection, or open wire
10 - Baro sensor, or connection, or wiring
11 - Vehicle speed sensor, or connection or wiring
12 - #1 injector connection, or faulty injector
13 - #2 injectior connection or faulty injector
14 - #1 connection or open/shorted circuit
15 - #2 connection or open/shorted circuit
18 - Cam pulse sensor, connection or loose sensor
19 - Ignition pulse sensor, connection or loose sensor
20 - faulty E-PROM in ECM.
https://cbrforum.com/forum/f4i-main-...de-13-a-54767/
Googling codes works wonders
Old 03-30-2014, 09:51 AM
74demon's Avatar
What's with all of the speed sensors around here failing recently?
OP, does your Speedo do wacky things?
Old 08-04-2015, 01:51 PM
redder's Avatar
I think my speed sensor is failing.
For some time now when I first start up the speedo is fine but after 200 or so yards it drops to zero, it can stay like that for a mile then comes back and works fine for the rest of the 30 miles to work.
If it does go to zero for that long?(sometimes shorter) then the FI light comes on solid. A cycle of the ignition extinguishes and it won't do it again usually until the next morning.
This evening it happened and when I parked up I noticed the solid light start flashing. I noted one long followed by one short.
And this is where I ended up!
Thought I'd post my experience in case anyone else comes across it, it isn't bothering me a whole lot but since I now have the code I wonder how hard this part is to replace?
Thanks in advance for any replies.
Old 08-11-2015, 07:37 AM
redder's Avatar
Never mind, I've found the HOW TO from 2010!
Quick Reply: FI light 2001 CBR 600 F4I
