Fender eliminator
Thank you for the link below, just what I was looking for!! Need it to get my military decale...thank you!!
ORIGINAL: Ricepowered01
i made my own fender eliminator kit that looks like the ss kit. i will post pics when I can. what I did was I took the bracket off the front wheel fairing that holds you reflector on. then I took the bracket and grinded down the back of the bracket to make it flush. so you can you shorten bolts. then I took the battery out and there is a little hole in the bottom of your tray. that is where I mount it. then you take a bolt from you license plate HW. making sure the reflector mounting spot is down insert the bolt threw the bracket to your license plate. tight bolt. then from the back drill a small hole threw the other bracket hole into your plate. then take a small flush screw and insert it from the front of the plate and tighten. next loosen other plate bolt and install license plate frame. which will cover the small flush screw. then install on to bike and adjust for you preference. also there is a bolt hole under your fuse holder next to the battery. The Job took me about 30 min and 60 cents for bolts, nuts and washers from ace. Then if you want lights you can add a led bolts or frame from here http://www.customdynamics.com/illumi...0Plate%20Frame
it is easy, I did not have to spend money or drill into my bike to do it i will try to post pics tonight or email if you would like pics of the whole projec
