Fender eliminator
Old Apr 6, 2006 | 08:07 PM
Royce's Avatar
Default Fender eliminator
Hello,
I have been seriously considering buying a Competition Werks Fender Eliminator kit.
I was also considering making my own home made version of the same basic thing. I have purchased an LED strip for lighting up the license plate. I plan to get a clear alternatives brake light with integrated signals. The only thing I have to build is the actual license plate holder.
Has anyone out there created their own fender eliminator for the 2003 600 RR?
Thanks,
Royce
Old Apr 6, 2006 | 10:14 PM
cbr04's Avatar
Default RE: Fender eliminator
there are quite a few members with home-made kits. some don't look too bad but i can't recall of one that sits as far underneath the tail as the Comp Werkes kit. that's why i like it so much. looking at the CW kit, it doesn't look too difficult to replicate but that's coming from a person who doesn't know what he's talking about half the time (me!)
Old Apr 7, 2006 | 06:25 PM
brancart1's Avatar
yea i wouldnt think it would be too hard, i just went ahead and bought the CW kit, but i dont really know how to shape sheet metal, so i guess what ever ur skills are
Old Apr 7, 2006 | 07:55 PM
Ricepowered01's Avatar
i made my own fender eliminator kit that looks like the ss kit. i will post pics when I can. what I did was I took the bracket off the front wheel fairing that holds you reflector on. then I took the bracket and grinded down the back of the bracket to make it flush. so you can you shorten bolts. then I took the battery out and there is a little hole in the bottom of your tray. that is where I mount it. then you take a bolt from you license plate HW. making sure the reflector mounting spot is down insert the bolt threw the bracket to your license plate. tight bolt. then from the back drill a small hole threw the other bracket hole into your plate. then take a small flush screw and insert it from the front of the plate and tighten. next loosen other plate bolt and install license plate frame. which will cover the small flush screw. then install on to bike and adjust for you preference. also there is a bolt hole under your fuse holder next to the battery. The Job took me about 30 min and 60 cents for bolts, nuts and washers from ace. Then if you want lights you can add a led bolts or frame from here http://www.customdynamics.com/illumi...0Plate%20Frame
it is easy, I did not have to spend money or drill into my bike to do it i will try to post pics tonight or email if you would like pics of the whole projec
Old Apr 8, 2006 | 04:49 PM
Royce's Avatar
I'd love to see the pics. Thanks
Old Apr 10, 2006 | 10:12 PM
cant post pics i will email them to you if you like
Old Apr 11, 2006 | 11:46 AM
BryanB's Avatar
Could u email me pics too please?
Old May 27, 2006 | 09:55 PM
smarterben's Avatar
could i have pix emailed???
smarterben@gmail.com
thanx
Old May 27, 2006 | 11:11 PM
ROADRUNNER's Avatar
i will be getting my CW kit when it is available it should be in my hands and installed by June 15 at that time i will post some pics of how its looks and how it came out.......I really think that it isn't worth making a custom one compared to the CW but hey that is just my opinion....only if you want to mount it elsewhere other way under the tail.......
Old Jun 1, 2006 | 04:12 PM
Repsol JF's Avatar
I've just got the Competition Werks Fender Eliminator kit for my Repsol and it comes with a set of the rear blinker as well. I've just put in on my bike and it looks great.
