Fairing does not want to stay clipped in...
Old Apr 11, 2012 | 06:17 PM
NTXcbr600rr's Avatar
Question Fairing does not want to stay clipped in...
Since I got the bike it has had this problem.
The right upper fairing does not want to stay clipped into the tank, and so it hangs off a half an inch or so...
Not noticeable to others, but an eye sore to me.
I've tried taking it off and seeing if there was something pushing the upper section off, but there does not seem to be anything protruding enough to push that section off.
The clips also seem to maybe be a little worn. Is there anything I can do you reinforce the clips to make them stay?
Any ideas?
Thanks!
Old Apr 11, 2012 | 10:55 PM
Here is what I think.
A picture is worth a thousand words...
Old Apr 12, 2012 | 12:37 AM
Dirtrider009's Avatar
While i agree with
You can just buy new clips, they usually sell the whole set (all the clips for all the fairings) but im sure you can find singles somewhere.
Old Apr 12, 2012 | 09:59 AM
Its supposed to push into the tank and click. it kinda does, then pops back off again.
Old Apr 12, 2012 | 04:41 PM
What do you know about the history of the bike ? How do the screw holes line up on the rest of the fairings ? Any possibility of bent brackets or crashes in it's past ?
Old Apr 12, 2012 | 08:47 PM
Everything seems to be aligned, one owner, only has 6.9k miles. No scuffs on any fairing or any of the metal or frame. I took them completely off to check of it just wasn't properly installed, but it appeared to be
They will clip........ Then they pop out. The clips seems to be a little worn on the indents that would hold it on. Anything I could do I reinforce those without just putting some 3M tape under it?
Old Apr 13, 2012 | 12:31 AM
No body has any thoughts?
Old Aug 11, 2012 | 11:32 AM
Kiknit's Avatar
New Member
Default Bump same problem
Same problem need help!! I think too much of the clips has broken off mine. If I could figure out how to post a photo with my phone on here I'd be posing the same photo.
Old Aug 11, 2012 | 11:34 AM
Kiknit's Avatar
New Member
Same problem need help!! Exact same thing with mine!
Old Aug 12, 2012 | 02:20 PM
kcrews123's Avatar
Registered Users
Just buy new clips. They tend to get word down after they've been removed and put back in quite a few time.
