F4i starter motor question
Old Nov 11, 2008 | 12:56 AM
OnEWhEeLNEAL's Avatar
Default F4i starter motor question
Just installed a new to me motor and Im having a whole slew of problems. Spoke to omr who advised me that one of my problems may be a shotty starter motor. Ive never removed one before so I looked at the service manual as well as my old motor. The service manual says to drain the coolant, remove the throttle bodies, remove the thermostat housing and then remove the nut and starter motor cable from the starter motor in order to be able to get the starter motor out.
Service manuals from what Ive seen so far tell you to do a whole bunch of unneccesary **** so I was just curious if anyones done it before and if so, did you do it this way or is there an easier way to get to it Checking out my old motor it seems as if I may have to do all this but figured Id ask before getting busy tomorrow. This might not even fix the problem Im having but its worth a shot. Oh and FYI - installed new to me motor. Bike was starting up from a cold start no problem. When the bike would warm up it wouldnt start as easy. It would turn over but not start. After a minute or two I would give it another go and hold the throttle open while trying to start and after 5 or so seconds it would start. So far, I fully charged the battery and swapped stators with my old motor but still the same thing is happening. Tonight though after the bike warmed up, I tried to start it and now it wont start at all - even after a few minutes of letting it cool down
Other things Ive changed - new plugs, swapped coil packs from old motor, swapped throttle bodies & fpr from old motor and used my existing wiring harness, regulator/rectifier, computer, ect. and thats about it. Appreciate any info on removing the starter motor or any helpful info if any of yall have had this happen before
Oh and one more question - if its absolutely necessary to do it the way the manual says, the manual calls for a new O-Ring to be installed when putting the thermostat housing back on. If I reuse the existing one will that be a problem or could I use it so I dont have to wait til I get a new one
Appreciate the help
Old Nov 11, 2008 | 03:48 AM
bigjohnstud4200's Avatar
Default RE: F4i starter motor question
While, I can't answer all of your questions, I can say this. Based on where the starter motor is, it does sound like all steps are neccesary but don't quote me. As far as the O-Rings go, how long has the motor been sitting around? If it's any signifiant amount of time, I would get new rings for sure (would get them either way b/c I wouldn't want to miss a chance at replacing that stuff only to find out you have to get back in there and do it anyway) due to dry rot.
Old Nov 11, 2008 | 12:46 PM
Yeah the motor was sitting in a salvaged bike outside for close to 2 years so I guess I have to order the orings then. Dam I just wanna ride already Arghhh oh well. If anyone else has any suggestions on taking the starter out lemme know. Thanks. [sm=icon_cheers.gif]
Old Nov 11, 2008 | 07:54 PM
ORIGINAL: OnEWhEeLNEAL
My bike sat in a home garage for 2 years while the previous owner was in Iraq. When I started it, it was spitting fuel out of the o-rings in the fuel line and up in the carb. You may want to look into doing those also, it wasn't too difficult a job either.
Old Nov 12, 2008 | 12:27 AM
Mines not a carbed bike so that wouldnt apply? What should I be looking for on a FI bike? I went to take out the throttle bodies tonight and realized I dont have a long enough screwdriver to get in there and loosen the screws. So tomorrow I'll get the biyatch out and hopefully make some progress.
Old Nov 12, 2008 | 12:36 AM
good point about the o-rings in the carbs. Not sure how the Fi is done, but I do know that there was a fuel line going to two Y connectors on the carbs. The Y connectors in the carbs had o-rings on them also and I can only image that there has to be some o-rings somewhere connecting the actual fuel line to the fuel system on your bike.
good luck bro!
Old Nov 12, 2008 | 12:50 AM
justasquid's Avatar
It does sound as it could bea starter problem. But before I did that, I would take your battery in and have it load tested. a weak battery will act the same. You may have the proper voltage, but not enough amps to start it when the battery warms up from charging.
Old Nov 12, 2008 | 12:53 AM
ORIGINAL: justasquid
Step ahead of you - sorta lol. We took my battery and put it in my buddys bike and his started right up. Then we took his battery and put it in my bike and it still did the same thing. Tomorrow Ima get the starter motor out and swap it with the one from my old motor and hopefully that will solve that problem. Then I have to figure out why this motors running rough and the idle is inconsistent and surging all over the place. Thanks for the tips and advice guys - keep em coming if you got any other ideas.
Old Nov 12, 2008 | 12:54 AM
ORIGINAL: bigjohnstud4200
good luck bro!
Yeah ima check it out tomorrow and see whats what. Thanks mayn.
Old Nov 13, 2008 | 12:23 PM
skoobydoobie's Avatar
the spuratic idle sounds like the FPR (fuel pressure regulator), the fact it wont start when it warms up sounds like a fuel pump. good luck
