F4i OWNERS HELP!
F4i OWNERS HELP!
any F4i owners that can tell me which order the wires from the kill switch go in? the green and yellow wires that come off pretty easily. i took mine off and cant remember which goes to front and which goes to back!
I have an 01 f4i if the year makes any difference
thanks!
thanks!
The Engine Stop switch only has 2 wires going to it. One wire is Black and the other is White/Black. It doesn't matter which wire goes to which terminal.
The other switch there is the Starter Switch. That has a Yellow/Red wire and a Black wire. Those have continuity when you press the Starter switch. The other 2 wires are the Black/Red and the Blue/White wires. They have continuity until you press the Starter switch, then they open.
I'm not sure about any Yellow or Green wires. Maybe you're referring to something else. Can you post a photo ?
