F4i Headlights
Hi all- About those blue Xenon H7 bulbs you can put in the F4i, they come two in a pack but I think that its two low beams. Can I put the low beam bulb into the socket for the high beam and just ride with both bulbs lit all the time, or do I have to order a pack of low beams and a pack of highbeams? Thanks
If the lights are like I think they are, then you need just 1 pack of the same wattage (should say on th back of each headlight cover) If they are like the 600 RR's headlights, then they run exactly the same, the only difference is how they are reflected/refracted... whatever... They light for high beam is a "line beam" and the light for running is just bounced all over the place off of the back of the housing... DONT TAKE THIS TO HEART, AS I DONT HAVE AN F4i... just saying "I think"
take it easy,
chris
take it easy,
chris
