f4i died and wont start
Okay here's what happened...
Me and my friends were going towards downtown, when we were getting off the highway my bike started to kinda misfire, and run pretty rough. So I got off the highway shut the bike off and it wouldn't start again, it would crank but the fuel pump wasnt priming, I checked all the fuses and they r fine.
So I got the bike home in a van =[.....took the gas tank off, pulled the fuel pump and connected it to a 12v power source and it sure works.......then I checked the connector and its not giving any power to the fuel pump.......im getting an error code 14 (one 1.3 second blink and 4 short blinks) which is injector #3.......im kinda lost here and just wondering what could be causing this....
I would really appreciate any help
If the pump doesnt prime its either a saftey switch or the fuel pump relay. Get an "ohm" meter and check for voltage on both sides of the relay. If you got power "before" the relay but not after, then thats your problem. If there is no power going to the relay then start "jumpering" saftey switches. (kickstand switch, Bank Angle Sensor, clutch switch, ect.)
