f4i blew 3 fuel pumps, anyone have any ideas what it can be?
Please help...I have gone through 2 fuel pumps in less than 30 miles. What could cause my bike to go through 2 in 24 hours? I install them and they work fine, bike primes and starts right up. Then I come back the next day to start the bike and the fuel pump will not prime? Put in another, started right up, 2 days later it will not prime either. Originally the bike had the original fuel pump in it. The bike sat for a yr and when I went to start it, it would not prime. The gas is fresh and clean since we drained the tank both times. No warnings at all. I shut the bike down a few times as well...Fuses never blew and relay still seems to work... I hear it when I put the key in as with the 2 times prior to this.
Tia
Tia
Are you sure the pump isn't working? I'm thinking it's possibly the engine cut off switch rather than the pump. The F4i is known for this switch failing. I'd disassemble the switch, check the contacts, clean it, and try again. It could be intermittent, so if the switch primes the fuel pump at one point, it may cut off when you're riding, or not prime another time.
Tia
Tia
