f3 wont start? relay just clicks?
ok my 96 f3 wont start unless i push start it.
& when i try to turn it over the starter relay clicks repeatedly nothing else. i've replaced the starter, regulator, starter relay & battery. |
RE: f3 wont start? relay just clicks?
wheres the kill switch on these ? & how do bypass it?
Kill switch is on the right handle bar, but even when on you should not get the 'click'. Just the lights on. Even though you replaced the battery, did you fully charge it?. Check the connections the starter again, check your fuses.
its also very possible that your battery cable, or one of the wires somewhere is corroded and damaged as a result, preventing the starter from recieving the proper voltage, which could be your problem.
2 Attachment(s)
OH SHYT!! That is not good at all man [:o]
I'm a new to motorcycles and am thinking about buying a 94 CBR 600 and I think that's what wrong with it. What priec of the bike is that called and how do I fix it
@Deepsixed9 Hi and welcome to the forum. If your engine looks like this section of the starter drive, then you don't fix it. You get another engine. Ebay is going to be your friend on this one.
https://cimg2.ibsrv.net/gimg/cbrforu...52d36abeed.png |
Originally Posted by Deepsixed9
(Post 1351660)
| All times are GMT -5. The time now is 01:10 AM. |
