F3 Head light help
Old Aug 9, 2007 | 05:14 PM
clean929's Avatar
Default F3 Head light help
Ok this is what i have , 98 f3 we went out for a quick ride and all of the sudden just the head lights stop working.
took it apart and check to see if the plug that connects to the bulb was getting power.. no luck.. eberything ealse works, signals,rear lights, cluster ...just the head lights... when turning on the HI beam the indactor on the cluster does not get on.
any ideas?anyone?
Old Aug 9, 2007 | 06:24 PM
uglyangelracing's Avatar
Default RE: F3 Head light help
I had a similar problem last week. Only my right turn signal stopped working. I checked everything turned out it was the switch. Also did you check for power at the relay?
Old Aug 10, 2007 | 12:12 PM
RichB's Avatar
Did you check the fuse? Sounds stupid, but you didnt mention it so I wanted to check. I lost all my auxillary lighting, gauges, basically everything except the headlight and found a busted fuse, and I noticed that the headlight is on its own fuse, atleast I think I remember it being that way. Check that if you havent already
dizzle46
Jan 29, 2008 05:33 PM
serge1284
Jan 21, 2008 04:22 PM
djtrix92
Dec 12, 2007 04:54 AM
burn8756
Jul 9, 2006 04:43 PM
Shlock
Oct 2, 2005 04:07 AM
