f2 rubber carb manifolds
Old Jun 27, 2011 | 07:07 AM
graygeezer's Avatar
Default f2 rubber carb manifolds
I removed and disassembled the carbs on my '94 f2. The rubber manifolds seem to be hardened from heat/age, should I change these? I wasn't sure if it I should automatically replace them. They aren't cracked or anything. All of the clamp bolts also seemed real loose to me. I know they need to be snug to seal the intakes but how tight should they be? The repair manual doesn't really say.
I was going to really crank them tight when I put it together, even thought using a little lock tight on the threads. I have the stock jets in it now, should I replace them? I mean, do they wear out or anything? Any help/suggestions would be appreciated.
Old Jun 27, 2011 | 12:19 PM
Monkeybutt2000's Avatar
You can get new onee on ebay for $30 shipped,get'em.
Old Jun 28, 2011 | 08:36 AM
DammitMike's Avatar
I never ended up removing the carbs on my old Ninja, but while researching it, I found a lot of people would boil the boots in water to soften them up before reinstalling. If you can get a new set for $30 thpough, I'd do that. I think new Kawi ones were going for over $30 each!
Old Jun 28, 2011 | 10:23 AM
graygeezer's Avatar
Thanks, I checked em out, I'll pick up a set
dyracuse
Feb 9, 2010 02:06 AM
rmccann87
Dec 29, 2008 10:19 PM
rrasco
Apr 21, 2007 03:55 AM
