Engine Stop Switch
Old May 31, 2010 | 04:21 PM
Tallat2J's Avatar
Default Engine Stop Switch
I recently bought a 2007 CBR600RR. I took it out for a ride last week and when I parked the bike I accidently turned the Engine Stop Switch OFF. The bike sat for a week... and now it won't turn over. It acts like the battery is drained. When I hit the starter it just clicks (ticks) really fast. I read in my owners manual that the engine stop switch should normally remain in the run position even when the engine is off. Is it feasible that by turning the Engine Stop Switch to the off position that it drained my battery or do I have a different problem? What should be my next step? Thanks for your help.
Old May 31, 2010 | 04:24 PM
dmcb2120's Avatar
Said like the battery is just bad. Maybe it was on it way out then sitting for a week finished it off. I usually turn my switch off when I coming home late and just coast into the garage so I wont wake up my family, but I have never had a battery problem from it .
Old May 31, 2010 | 06:45 PM
kilgoretrout's Avatar
Administrator - Retired
Nope.
The only way your battery would drain is if you left the ignition on, you have a parasitic draw from somewhere else, or you battery is just dead from sitting so long.
It's most likely either a decent battery that's just totally drained, or you need a new battery.
What I would do is charge the battery to max and see how it does. If it's still not taking a charge right, or its discharging quickly, get a new one. Many people also hook up a battery tender to their bikes.
Remember also, that most bikes don't charge the battery at idle. (like a car would). You actually need to have some rpms to get a good charge to it.(3k+)
If it's deeply discharged, this can take a lot of riding.
sirtexas99
Mar 3, 2011 12:41 PM
Jermz
Jan 27, 2011 08:50 PM
Tweeter03
Jun 11, 2010 11:09 PM
abelg
Jul 19, 2009 07:23 AM
FordFrenzy97
May 30, 2006 07:48 PM
