Engine Rattle
Old Oct 16, 2006 | 03:00 PM
  #21
Tahoe SC's Avatar
Default RE: Engine Rattle
here you go mang...
[IMG]local://upfiles/2436/A7C2A179FBF24754ADDE2243009BC068.jpg[/IMG]
Old Oct 17, 2006 | 12:02 PM
  #22
joesrods's Avatar
Thanks Tahoe so where is this screw that I have to turn and how many times do I turn it? Until it gets tight? Until I cant turn it anymore? Thanks
Old Oct 17, 2006 | 01:47 PM
  #23
Tahoe SC's Avatar
at the very bottom of the cctl, there is a bolt with a crush washer if you remove it. in the pix, the bolt has been removed...put a small screwdriver in it, turn it to the right, the cctl shaft retracts...if you turn it counterclockwise, it pushes the shaft out...be careful with this one...at the most i would just take it apart and put extra winds in the spring and flare the tip. when you start doing the manual thing, you have tightness that you've adjusted and tension from the spring on the cam chain, which may be too much...just really don't know how tight it is.
Old Oct 17, 2006 | 02:18 PM
  #24
joesrods's Avatar
gotcha thanks again!
oldnotslow
May 30, 2017 02:38 PM
bri-man
Aug 15, 2012 09:34 AM
dougie cee
Oct 9, 2009 09:38 AM
corrcullen
May 16, 2006 11:59 PM
