Engine has fallen and won't turn
Old Oct 8, 2011 | 04:28 PM
danroonie's Avatar
Default Engine has fallen and won't turn
argh
I was working on fixing my valve clearances. Couldn't get my intake cam sprocket on so I turned the the engine a little bit backward (counter-clockwise). I think I screwed something up royally cause I couldn't get them on.
So i took both the camshafts off again- and now I can't turn the engine forward at all! Rather than force the pulse generator and break a rod or chain or something, I figured I would post here.
What have I done and what can I do to get back on track?
For the record, I retracted the cam chain tensioner, and removed the spark plugs.
Old Oct 9, 2011 | 05:31 AM
MadHattr059's Avatar
Only thing I can think of is the cam-chain might be bunched up in the bottom end of the cases on the crank. Try tugging it up to get the slack out and see if that let's it turn freely. Then, rotate the engine thru to get your timing marks lined back up.
Hope that does the trick, Ern
optytrex
F2 Tech
18
Feb 7, 2015 12:18 PM
Lawrence Norton
Dec 24, 2013 09:16 PM
dyracuse
May 11, 2012 08:57 PM
sra_chipmunk
Dec 17, 2007 08:09 PM
Scrufdog
Jun 11, 2007 03:37 AM
