dyno tuning question about altitude
Old Mar 6, 2008 | 10:15 AM
linkandcuff's Avatar
Default dyno tuning question about altitude
a buddy of mine has a motorcycle shop in western NC which i think he is around 2,000-3000 ft above sea lever..(he is right near deals gap if u know where that is) but he can tune my bike when i go on my motorcycle trips down there but i live in upstate ny where its about 600-1000 ft above sea level....i have a 954 so since its FI does it matter where u get it tune....he said it should be fine but just wanted to hear it from someone else.
Old Mar 6, 2008 | 11:39 AM
Lrn2Go's Avatar
Default RE: dyno tuning question about altitude
It will work either way... the computer usually does a good job compensating for the change... however I wouldn't think that the tune would be accurate when you get to where you normally live all the same. The figures would be off. This isn't going to hurt anything... but I would think that if you dyno'd and checked it back out when you got home that it wouldn't match what you had done at the higher (1-2 THOUSAND feet mind you) altitude. But who knows... at the lower it might run even stronger!
Old Mar 6, 2008 | 01:59 PM
i'm sure it would put up higher HP numbers at lower altitudes as longs as my air/fuel ratio was good at either level that would be great..which i was thinking like u that the ecu would be able to adjust to the level but just wanted to hear some other peoples thoughts
scooterc14
Mar 13, 2011 01:27 PM
HockeyFan
West
Mar 19, 2009 06:41 PM
jonld
Oct 2, 2008 06:07 PM
ampfp
Sep 28, 2007 09:32 PM
AKRider
Apr 5, 2006 03:21 AM
