draining coolant
Old Sep 18, 2021 | 01:39 PM
dannnv's Avatar
Default draining coolant
Im trying to drain the coolant from my 1994 CBR1000F. I have seen the temperature climb higher than normal recently and want to make sure I dont have corrosion.
I cannot find any pictures of the correct bolt. Anybody have this ? I also think i might have turned an adjustment screw near the water pump by accident maybe misread someones instructions. There is a screw that takes a flat screwdriver I think that is clamped with a ring with a bolt. Near the bolt are some small marks. Any idea what this is? Did I mess something up?
But additional can someone point out the drain plug?
Many thanks
Old Sep 18, 2021 | 04:41 PM
amosjr's Avatar
See if you can find the shop manual, it'll make life much easier. Sometimes there are 2 bolts to drain from, my F4i has 2. A few other tips, use a torque wrench and but a kit of copper crush washers. The kit is cheap and you'll have less worries about leaky washers when you do oil changes, coolant changes, brake lines, etc...
mark966
Apr 16, 2013 05:41 AM
mcastro253
Jul 1, 2012 12:16 PM
piresito
May 16, 2012 05:46 AM
xvcydvx
Mar 24, 2009 10:27 AM
faux
Jun 26, 2008 08:51 PM
