Decal removal
Greetings, I want to remove a few of the decals on my 06' 1krr, but worried about paint comming off with them. So, any recomendations? I'm thinking get a fine blade, and slowly work up a corner and slowly peel off the parts I want gone. Are the decals thick, like come off in one peice? Can you tell where they were once they're gone?? Thanks for any input.
the best thing to do is get a heat gun and melt the stickers a bit to soften them up and they should peel right off you might have to get some goo gone or something to remove any glue left on the plastic but no it aint gonna take the paint of just stay away from the fine blade idea
all you need is a hair dryer and slowly warm the decal slide a plastic blade under the edge and slowly pull if the decall tears that ok just keep pulling slowly. after the decal comes off soak meneral spirits in a rag and lay on top of the glue let set for about a min and then the glue will roll up in little ***** and come off.
Don't know why I didn't think of the heat-gun, what a no-brainer. The fine blade idea, was to just get a razor and slowly, carefully work up a corner and then peel it off slowly by hand, I wasn't gonna shave the thing off, sorry if any misscommunication on my part. I'll try the heat gun this weekend.
