Custom Seat
Old Jun 28, 2007 | 03:31 AM
xtremef4i's Avatar
Default Custom Seat
I want to redo the foam on my seat for a softer place to rest my butt on long trips. I am recovering the seatand was wondering if anyone has ever rebuild their seats using a different kind of seat foam that is still firm, yet softer than factory and that maintains the factory shape and size of the seat. I am doing front and back seats and do not want to spentd the big bucks on a Corbin,they are hard anyways...I was leaning towards memory foam or furnatire foam. What has anyone else used? Any suggestions? thanks
Bike is 2001 F4i
Old Jun 28, 2007 | 03:54 AM
rippn's Avatar
Default RE: Custom Seat
Go to a upholstry supply store and discuss your needs.. the key is progressive densitys in layers inspecific places. If you are adding a layer for long run comfort... thebottom layer, should be denser... even to the point of an "rebond" insert, across the hip points. the densuity, will make the diff.
Free and clean, Ripp'n
Old Jun 28, 2007 | 03:59 AM
mmookey's Avatar
+1 on the upolstery store. Thinking about saving me some money and doing it myself. Only problem is that if I mess up I am force to buy a new seat.
Old Jun 28, 2007 | 10:29 AM
xtremef4i's Avatar
So then I should deffinatly go with memory foam as my seat pad, using different densities and weights? Is there a need to leave a little bit of the factory foam in place at the botton to procide the basic shapr and suppurt or just gut the seat completely and rebuild it with memory foam? thanks
Old Jun 29, 2007 | 05:21 PM
xtremef4i's Avatar
anyone else have any suggestions??
Old Jun 29, 2007 | 05:46 PM
D2VW14_20's Avatar
I did mine myself, I did a write up a while back.......
Old Jun 29, 2007 | 05:47 PM
D2VW14_20's Avatar
Here
https://cbrforum.com/m_212719/tm.htm
Old Jun 30, 2007 | 07:36 AM
xtremef4i's Avatar
D2DGraphix...thanks that helped me a little bit more. I feel better about doing the seat now. I read in your other post that you used memory foam. That is what I was planning on using. Where is a good place to other than Ebay? Also, do you happen to know what the pound and density rating of the memory foam was and how thick the foam was you used for your seat? I assume it has to be somewhat firm since it will give quite a bit when I sit on it. Thanks.
Old Jul 2, 2007 | 09:06 PM
uglyangelracing's Avatar
I used a memory foam pillow I bought at wal-mart. Cheap way out.
Old Jul 2, 2007 | 09:13 PM
D2VW14_20's Avatar
I went to Jo Ann Fabrics
