crossed the +/- cables on battery...wont start. HELP
Old Jan 12, 2006 | 01:58 AM
a1yola's Avatar
Default crossed the +/- cables on battery...wont start. HELP
Hello. My friend tried to jump start his 02 F4i and accidentally corssed the positive and negative cables. he said that it wont start anymore. Does anyone know what this oculd be?? he said he checked the fuses and they seem to be good.
Old Jan 12, 2006 | 04:37 AM
Muz's Avatar
Muz
Default RE: crossed the +/- cables on battery...wont start. HELP
First off what do you mean by doesn't start, does it turn over? I would double check the fuses. I takehe was jumping it because the battery was flat. I would make sure that battery isn't dead
Old Jan 12, 2006 | 07:29 AM
shraz's Avatar
fuses
Old Jan 12, 2006 | 09:30 AM
chainstretcher's Avatar
Admin Emeritus & MVN
Make sure the battery is good then turn the key and splain to me exactly what it does. If nothing comes on (lights, gauges etc) then I'd recheck the fuses with an ohm meter. If they check out o.k. then I'd examine the regulator/rectifier.
Old Jan 12, 2006 | 01:08 PM
Tahoe SC's Avatar
i think he blew all his fuses mang!
Old Jan 12, 2006 | 10:04 PM
WolfPack's Avatar
How did he jump it.....car with motor running, car with motor off, another bike running/off....I saw many people come into the Motorcycle dealership i used to work at who jumped their bike from a running car and melted the rectifier and fuse block...
If you jump a bike, always do it from a non-running (12v of course) vehicle....12v is 12v no matter what, but as soon as you are jumping from a running motor, the alternator is pushing amperage
Old Jan 12, 2006 | 10:17 PM
transamlt1man's Avatar
I would be amazed if it didn't blow a fuse. So check them again.
Old Jan 13, 2006 | 07:43 AM
fishfryer527's Avatar
My vote is with Muz, probably an internally shorted out battery. I would assume that the F4i doesn't have a circuit breaker, only fuses.
Old Jan 13, 2006 | 04:35 PM
Tahoe SC's Avatar
to check to see if the battery is dead...lick both your thumbs, put a light bulb in your mouth, and then attach the wet thumbs to the battery posts...buahahahhah...
disclaimer...if you do it...you did it out of your own will.
Old Nov 9, 2016 | 03:56 PM
Tommy Welch's Avatar
i did the same thing, is the 4 fuses under the throttle the only ones or is there a main fuse??
