crazy gauges
Old Oct 31, 2007 | 02:37 PM
mpbigham's Avatar
Default crazy gauges
i was riding yesterday, and i noticed when i would hit a bump, every gauge with a needle on my bike would bounce down, and come back up, the odometer would flip on and off too
any clues?
there is still power when this happens, the lights behind the gauges stay on
Old Oct 31, 2007 | 02:44 PM
cbr6oo's Avatar
Default RE: crazy gauges
Sounds like you have a short or loose conection somewhere....
Old Oct 31, 2007 | 03:59 PM
§T®ÈÈT¿ÃÈMOÑ's Avatar
sounds like a bad ground to loose everything like that or just a bad connection like cbr600 said, could be a bad solder joint in the cluster itself but i doubt it
Old Oct 31, 2007 | 04:56 PM
Blue Fox's Avatar
Retired Moderator
I bet your connector is dirty or loose. My car had a similar problem, and when I would hit a bump, the entire gauge cluster would turn off, and then flicker. I took out the gauge cluster and found the connections were loose. I would try that first, and if it still does it, check the ground like §T®ÈÈT¿ÃÈMOÑ said.
Old Nov 1, 2007 | 09:58 AM
mpbigham's Avatar
hey fellas
thanks for the input, i haven't had a chance to check it yet, but tommorow being friday and all, i'll look at it and get back
Old Nov 17, 2007 | 06:10 PM
mpbigham's Avatar
ok so i finally laid hands on my bike. i started at the battery. the positive cable's bolt had come undone. the bolt was still through, but there was no nut on it to keep it in place. got a new one, fixed the problem. ta da
Michaud85
Apr 17, 2011 12:36 AM
(951) Baby Shortee
Jun 7, 2009 05:18 PM
rangerscott
Feb 16, 2008 09:45 PM
steve00ses
Nov 6, 2006 02:17 AM
Repsol1
Jan 3, 2006 01:26 PM
