crazy gauges
i was riding yesterday, and i noticed when i would hit a bump, every gauge with a needle on my bike would bounce down, and come back up, the odometer would flip on and off too
any clues?
there is still power when this happens, the lights behind the gauges stay on
any clues?
I bet your connector is dirty or loose. My car had a similar problem, and when I would hit a bump, the entire gauge cluster would turn off, and then flicker. I took out the gauge cluster and found the connections were loose. I would try that first, and if it still does it, check the ground like §T®ÈÈT¿ÃÈMOÑ said.
ok so i finally laid hands on my bike. i started at the battery. the positive cable's bolt had come undone. the bolt was still through, but there was no nut on it to keep it in place. got a new one, fixed the problem. ta da
