Crank won't turn clockwise
Old Apr 29, 2019 | 10:00 PM
2andrewd's Avatar
Unhappy Crank won't turn clockwise
I'm just about to put the block back on after changing main and bi-end bearings and I was just about to put the block on when I noticed that the crank won't turn clockwise a full rotation. Counter-clockwise is fine but going the other direction it's like it just locks up but not always in the same spot and if I alternate directions it will unlock and spin a bit before locking again. The cam-chain isn't binding. What could be going on here? Thanks
Old Apr 30, 2019 | 02:05 PM
tentacleslap's Avatar
We'd need a bit more info. It could be a number of things...
I'd recommend starting a thread under the Hurricane section and documenting the work you've done and current status. Then at least you/we will have a fighting chance
Jeffrey Hartley
Oct 24, 2017 05:58 PM
bkoska1982
Apr 1, 2013 07:24 PM
dyracuse
May 26, 2012 09:07 PM
dyracuse
May 11, 2012 08:57 PM
little_leon60
Aug 3, 2006 09:31 PM
