-   General Tech (https://cbrforum.com/forum/general-tech-9/)
-   -   Crack or normal! (https://cbrforum.com/forum/general-tech-9/crack-normal-158058/)
cips007 Aug 11, 2018 08:55 AM
Crack or normal!
https://cimg0.ibsrv.net/gimg/cbrforu...a8d76b211.jpeg
Just been cleaning my bike and notice what looks like a crack on the left side back of engine to the right of the spacer. Can anyone confirm this is actually the shape of the alloy or is it a crack (centre of the photo!
cips007 Aug 11, 2018 05:06 PM
It’s identical on the right hand side too in exactly the same shape and place...if this is a crack,any ideas what could cause this and is it safe to use the bike!?
Andries Aug 12, 2018 02:07 AM
Take small piece of sandpaper and lightly sand it. If it's a crack you'll see it immediately.
cips007 Aug 12, 2018 02:10 AM
ok I’ll take a look,is this dangerous if it is a crack and is it a common issue?
cips007 Aug 12, 2018 02:26 AM
Ok I’ve just give it a sand and it’s disappeared!!
can anyone confirm this looks like this on the 2003 model?
cips007 Aug 13, 2018 09:51 PM
well it seems this isn’t normal,so I definitely have an issue on mine!!! I’ve lightly sanded this out,but am assuming if it’s a crack then it will reappear!! Firstly, is it safe to use like this as I’m assuming this part carries the weight of the engine?and secondly,is there anything I can do apart from what seems like I’ve been duped and may have to swap my engine?
hamlin6 Aug 14, 2018 05:01 AM
I would simply keep an eye on it. It very well may have been a small defect in the cast when the engine was made, leaving the small line
Since you sanded it and it didn't open up it doesn't seem like a crack
But again, just keep watching it and see if it presents itself again . My 2 cents anyway.
cips007 Aug 14, 2018 05:24 AM
ok I’ll go with that mate and thanks for your input,just didn’t want to worry about the engine dropping out on a run!!
hamlin6 Aug 14, 2018 06:06 AM
Very valid concern. It would make for an interesting ride if that happened. Better to be safe than very sorry.
cips007 Aug 14, 2018 06:22 AM
how serious does the crack need to be to risk collapsing on a ride?
