cornering; when do I shift???
RE: cornering; when do I shift???
It is less than desireable because you are slowing in the turn....if you are making very low speed parkin lot turns then its good....taking larger higher speed turns its not as good...if you must power through the turn at constant throttle with your hand covering the clutch just in case ....you want to power through because speed equals stability on 2 wheels....up to a point....
jnicola
F2 Tech
06-10-2010 01:35 PM
