colortune
Old Mar 31, 2011 | 06:21 PM
drzed1980's Avatar
Default colortune
Has anybody used the gunson colortune for there bikes?
Is it an effecrive piece of kit ?
any advice before i think of buying one?
thanks
mat
Old Apr 2, 2011 | 12:48 PM
Michaud85's Avatar
i dont think it will be a bad choice. never used one tho
Old Apr 2, 2011 | 03:29 PM
I bought one 2 weeks ago. Works well, though a little tough to get plug wire attached on some of the plugs. I was able to adjust each of the carbs to that "Bunson Burner Blue". I have 4 bikes, so got the 10mm and 12mm plugs. Can be tough getting a tool on the Pilot Screw though. I use the Motion Pro 90 degree tool. It helps a lot. It does take time going from one cylinder to another to make the adjustments. Just don't let the engine get too hot, or you'll keep burning your hands...lol.
Old Apr 2, 2011 | 03:46 PM
drzed1980's Avatar
did you find each cylinder a different setting?
i currently have all screws set too 21/2 turns out, which need tweaking in.
