Clutch doesn't fully disengage!
Old 05-04-2017, 08:40 AM
deaks25's Avatar
That is true, there is an extra element of drag when pushing a bike with a dipped clutch rather than being in neutral, but conversely, there shouldn't be excessive resistance that makes the bike hard to move, especially with a machine as light as the CBR, which is what it sounds like 12andom is getting.
The bike certainly shouldn't be pitching forward when starting in gear with a dipped clutch, as that indicates that clutch hasn't fully separated the crank from the drive.
Old 05-04-2017, 09:32 AM
12andom's Avatar
Originally Posted by 74demon
Not true. Neutral is neutral. In gear, you are adding the input shaft, clutch basket, and another gear to the equation. Higher gears have different ratios the turn the basket less.
Let's assume you are right. Why would it have changed? The answer that it is there is no problem after a change doesn't make any sense to me. I have a cbr600rr right next to it and it doesn't have the issue and felt like the f4i did before the problem. I put the RR on the same stand and it doesn't drag at all. I need possible solutions. Sounds like you may have the same issue if that is your normal.
Old 05-04-2017, 09:43 AM
wes 17's Avatar
I agree with 74demon here. There will always be a residual amount of drag which typically we don't feel as we're sat on it on the tarmac. It's normally not noticeable.
After a winter lay up, my clutch isn't at it's best until I've warmed up the bike and pumped the clutch a few times, just to free up those plates a little.
You could try this, or maybe a bit of adjustment to lessen your drag but ultimately, I believe drags going to still exist in some form.
Old 05-04-2017, 10:44 AM
12andom's Avatar
This definitely wasn't the first ride of the season that I noticed the change. I adjusted the clutch cable every which way and even had it pulled extremely tight just to see. Doesn't seem have improved.
I went ahead an ordered replacement plates and plan to open the clutch up. The challenge is finding that darn liquid gasket... Any leads?
Old 05-12-2017, 08:44 PM
12andom's Avatar
[UPDATE] my parts came in for the clutch plates, friction plates, clutch springs, and clutch cable. Replaced the whole stack. The clutch drag still causes the bike to lunge forward shifting to first. Out of ideas...
Old 05-16-2017, 04:31 AM
deaks25's Avatar
It might be time to bite the bullet & get the bike into a garage to be looked at.
HeavyCBR
12-27-2013 06:57 PM
Mitchelldietz
03-07-2009 04:46 PM
CtrlAltDl
11-07-2007 08:41 PM
dgw8022
02-01-2007 11:56 PM
chrisf
11-11-2006 05:12 PM
Quick Reply: Clutch doesn't fully disengage!
