Clear coat
Old Dec 23, 2007 | 06:35 PM
ajhundley3's Avatar
Default Clear coat
I just got my bike custom painted but I dont think they put enough clear coat on. Can someone tell me how to clear coat my bike. Do I have to take it apart or can I tape everything off and do it. On a scale 1-10 (10 hardest) how hard????
Old Dec 23, 2007 | 11:46 PM
mhonda98's Avatar
Default RE: Clear coat
If you had it painted at a shop take it back to the and get it fixed.Why do you think there isn't enough clearcoat on it?I would recommend trying it yourself.Its not the easiest thing in the world.I've painted for ten years and if you don't have enough clear than you will have to sand it and clear it all over if you want it done right.
Old Dec 26, 2007 | 04:05 PM
frankmackie's Avatar
i cleared my bike. you SHOULD pull all your fairings etc off and do it right. a good air-gun, good laquer etc. sand between coats and polish. i set up a booth with plastic to do mine to keep it in a controlled environment but to each his own. the prep makes all the difference. good luck!
Old Dec 31, 2007 | 08:37 PM
mhonda98's Avatar
I wouldn't recommend lacquer for my lawn mower it's not as durable as the clearcoats out today.I've had some many problems with lacquer in my years of painting bike and cars.They will not hold up against the uv rays and just dull out and fade after a while.
Old Dec 31, 2007 | 11:07 PM
TBFGhost's Avatar
+1 use modern two part clear coats.....
cbrfxsmithy_6_7
May 23, 2012 10:43 AM
jeffjones
Feb 22, 2011 09:25 PM
ajhundley3
Feb 11, 2008 08:00 PM
pr0jktmayhem
Feb 2, 2008 11:34 PM
ajhundley3
Dec 23, 2007 09:34 PM
