chain and sprockets
Old Jan 7, 2006 | 05:31 PM
city worker's Avatar
Default chain and sprockets
have a Q re: sprockets + chain, i need to replace mine ,1993 CBR 600F2 , i am told its a good idea when replacing chain to replace sprockets also, mine do not show a ton of wear but i figure the amount of strees they go thru riding ill do the sprockets also while iam doing chain , I assume the sprockets are stock size, front and back, as far as the amount of teeth on them, i have not counted them. my Q is, is it better to upgrade per say to more teeth or less teeth front or back??. i only ride street, no track or stunt riding. my next Q is what is a 5-20 conversion?? what type of chain is better than stock??
Old Jan 7, 2006 | 05:49 PM
pupdog_88's Avatar
Default RE: chain and sprockets
520 is refering to the width of the chain(5) and length of each link(20) (measured in eights of and inch i think?)your bike probaly came with a 530 or 535 the 520 is a little lighter and some say stronger, if your going to replace your spockets any way u should just get a 520 conversion kit and go down one tooth on the front sproket and up two on the rear your bike will really come to life you will lose about 10-15 mph of top speed but the bottom end will pull like a bull dozer, if your chain is bad enough that it needs to be replaced you definitley should replace the sprockets
Old Jan 7, 2006 | 06:18 PM
Anubis's Avatar
Just so you know the reason for replacing sprockets together with the chain is...... If you put a new chain on old sprockets the chain will wear faster, same applies with new sprockets and old chain. As for make, D.i.D all the way for chains. Best I`ve found.
Old Jan 7, 2006 | 07:04 PM
billy42's Avatar
From: clarion iowa usa born and raised in diamond-bar ca
1 down in front is like 4 up in the rear i was told and yes new sprokets is a good idea as well i went to a 520 conv on mine to 14 -44 i think and it is a lot better
Old Jan 7, 2006 | 07:34 PM
thank you for the info, ALL. my next Q is , with a 520 conversion kit , does that 'kit' come w/chain and sprockets as a complete pkg?? i just give bike info and number of teeth front and back?? or are these items seperate parts??
Old Jan 7, 2006 | 07:46 PM
NINE2NINE's Avatar
Retired Mod
ORIGINAL: city worker
yes. a 520 conversion kit comes with the front sprocket, rear sprocket, and appropriate length chain. everything needed to do the swap. check out calsportbike.com. they are a sponsor on here and they were offering specials on the 520 conversion. worth checking out. they should also be able to answer any and all of your questions.
Old Jan 7, 2006 | 07:48 PM
so all i do is give teeth specs???
Old Jan 7, 2006 | 07:52 PM
NINE2NINE's Avatar
Retired Mod
yeah. thats it. a normal upgrade is -1/+2 but anything you want (within reason) can be done. you can even go with stock gearing with the conversion.
Old Jan 7, 2006 | 08:08 PM
ok just looked at calsportbike.com, they dont list my year , 93, i e-mailed them to see if they do or dont
Old Feb 11, 2006 | 10:26 PM
edhcbr1000f's Avatar
Do any of you have the procedure for removement of the factory chain.
