Chain Lube
Old May 31, 2007 | 09:29 PM
rjporter's Avatar
Default Chain Lube
Does anybody know of Next Dimensions Chain and Cable Lube, and if so is it any good? Is it safe on the rubber in the chain? Thanks.
Old May 31, 2007 | 09:56 PM
knightslugger's Avatar
Default RE: Chain Lube
if it's chain and cable lube, you're using it on the wrong kind of chain.
use Honda Pro Chain Lubricant with White Graphite or another drive chain lubricant.
Old Jun 1, 2007 | 01:50 AM
rjporter's Avatar
Alright, thanks. I've been using gear lube like it says in the manual, but it makes a hell of a mess, after lubing, on the tire and farings. I will go to my local shop and check out the Honda lube.
Old Jun 1, 2007 | 12:41 PM
KidCr3nshaw's Avatar
Try to find some parafin wax. The stuff is awesome. Smells like crayons and as long as you give your chain a quick warm-up ride, then apply it and let it sit for 15 minutes - NO MESS! Just make sure you clean your chain really good before each application because it doesn't let much on or off the chain once it's there - if there's dirt there, it'll hold it on (dirt is bad, umkayy).
Old Jun 1, 2007 | 02:22 PM
fuze's Avatar
Pick up some PJ1 Blue label when you go to the shop, you won't regret it.
Old Jun 1, 2007 | 02:35 PM
N8 Dawg's Avatar
ORIGINAL: fuze
thats what I use....good stuff
I spent almost an hour cleaning my chain the other day....It was nasty when i first bought the bike...but I didnt scrub it before...now its all shiney!
Old Jun 1, 2007 | 06:00 PM
fuze's Avatar
Same here, i bought the bike and the chain was BLACK ! lol
WD40 is sweet !
[IMG]local://upfiles/16258/76C1364E13D74BBCB4F2F0B91353EDFF.jpg[/IMG]
Old Jun 4, 2007 | 01:26 AM
rjporter's Avatar
thanks for all the opinions. I heard PJ1is some good stuff, so i will probably go and pick some up. As for the black chain, that is how mine was when i bought the bike. I used some wd40 to clean the chain, but it still didnt get it all clean. I dont have a rear stand so it took a bit longer than i wanted it to.
Old Jun 4, 2007 | 03:06 AM
TK954RR's Avatar
Jan 2009 ROTM
wd40 is bad for o rings (which your chain has a lot of). I would rec. simple green or a similar cleaner
Old Jun 4, 2007 | 05:09 AM
frstplce1's Avatar
ORIGINAL: TK954RR
I don't want to start the whole WD-40 debate here, but Simple Green?
You think Simple Green is a better solution than WD-40? [sm=smiley13.gif]
Do you rinse it off with water after too?
