CBR400 NC23 Carbs questions
Old Dec 24, 2012 | 12:47 AM
udical's Avatar
New Member
Default CBR400 NC23 Carbs questions
Hi all.
Just bought me a nice quad of NC23 bike carbs.
These will be fitted to.... well... my car, an old MK2 Ford Fiesta.
I want to make sure the connections i make are right, as it's my first time with bike carbs.
Some of them, i have no idea what they are for.
So attaching pics and numbers.
1. Throttle cable?
2. Fuel intake hose?
3. Fuel intake hose?
4. ?????
5. Vacum advance for distributor? (x4)
6. ?????
7. WTF ? :-P
8. ?????
9. Fuel mixture?
Why on one carb there are 2 holes and on the other just one ? (same on the other side)
Thanks for the help !
Udi
Old Dec 24, 2012 | 08:52 AM
TahoeRider's Avatar
In the first pic #1 is the idle speed adjustment, #4 is the fuel inlet, #5 are the fuel bowl drain tubes. The other are vent hoses possibly for emissions I'm not 100% sure on those. #7 I don't know I'd have to check my parts diagram to see if something is supposed to go there. #8 is the drain screw for the fuel bowls shown on #5 there is 1 per carb. #9 is the mixture adjustment screw, also 1 per carb. Not sure about the last picture either I can't remember if my carbs are the same as those or not..
Old Dec 25, 2012 | 05:01 AM
udical's Avatar
New Member
Thanks.
An other question, is there a way to get vac advance for a dizzy from these carbs?
or i'll have to do it on the manifold?
Thanks!
Old Dec 25, 2012 | 11:06 AM
TahoeRider's Avatar
There should be a threaded hole in each carb with a screw capping it that's used to sync them.. you might be able to use that, but don't know how well it would work.
Old Dec 25, 2012 | 11:54 PM
udical's Avatar
New Member
Do you have maybe a pic of it?
may be this?
Old Dec 26, 2012 | 09:35 PM
TahoeRider's Avatar
I don't see them in the pictures, it's possible that those don't have them.. but there has to be a way to measure vacuum from each carb individually in order to sync them properly. However, it would probably be easier & might also be more accurate to just port it to the intake box.
Old Dec 27, 2012 | 03:51 AM
udical's Avatar
New Member
OK, Many Thanks :-)
Html33
Jan 21, 2013 01:39 PM
gogamoto
Jan 5, 2013 07:37 AM
Kernowjc
Sep 16, 2012 02:51 PM
SuperSized
Sep 10, 2010 10:36 AM
tony2things
Jun 5, 2009 10:29 PM
