CBR1000F 1989 leaking after winter
Old Feb 27, 2026 | 01:25 PM
Ed Harris's Avatar
Originally Posted by CBR1000 New
Also, now the tank is off and there isn’t a way to run the engine to see the leak, how can I know for certain where it’s from? Worth taking carbs out of is that overkill for this stage
Firstly, connect a vacuum pipe to the petcock, block the fuel outlet and suck on the vacuum pipe - this will show whether the petcock is leaking.
If not, connect a bottle to the fuel line (or, put the fuel tank on a shelf and run an extension hose to the fuel line) to run some fuel in and that will show where the leak is. (A quick and dirty would be to blow gently into the fuel line and feel to see where the air is escaping but …).
Old Feb 27, 2026 | 02:34 PM
From what I can tell from the last picture, that appears to be one of the fuel T's that distribute fuel between two carbs. If that is the case, they are known to crack or the o-ring on wither end of the T (carb side) could be bad. Given the amount of fuel in the video, I'd guess it would be a split rather than a bad o-ring.
Old Mar 4, 2026 | 01:52 PM
Hawkwind2016's Avatar
Just to let you know, you can just prop the tank up and run the bike to get a better view of what's happening. There should be a prop mechanism to do this.
Missynet
May 14, 2013 12:55 AM
Problemsolved
Rides
May 29, 2011 07:04 PM
Trips
Sep 3, 2006 09:16 AM
Trips
CBR Zone
May 19, 2006 11:23 AM
