CBR 900rr issues
Ok Lets see...every thing comes on lights, gauges, neutral light...my guess its flooded because ive been told that this model floods easily. when i turn the key on everythying comes on. Its not the battery. When i go to start it it trys to start but doesnt turn over. Its not the starter. Has a brand new rectifier and fuel petcock on it. Could it be the stator?
If it's cranking over but not starting it is probably either a lack of spark or fuel delivery issue. If it has enough power to crank the engine it's not the stator. The stator produces a/c voltage which is converted to d/c voltage by the regulator to charge the battery while the bike is running.
First things I would do is pull a plug wire out and check for spark. If you have spark it's probably a fuel delivery issue. Quick way to check for that is to spray some carb cleaner or starting fluid into the carb intakes & try to start it. If it fires you have a problem in the fuel delivery system.
I have a 93 cbr 900 and I had a similar issue, under my seat was wiring going to the rectifier and the wire going through a plug that was burnt and crappy looking, I cut the wire and spliced them back together and cleaned up the connections and now the bike turns over and runs fine. check the wiring under your seat!
