Carbs
Old Oct 3, 2006 | 10:42 AM
paul_k10_lx's Avatar
Default Carbs
hi guys im sorry if this is in the wrong place or i shouldnt even be posting this on here but here goes
im using a set of honda cbr 600 carbs on my car but the fueling is a bit low.
does anoyone know if the cbr 900 has the same carbs just with bigger jets or if they are the same fitment thanks alot for any help you can give
Old Oct 3, 2006 | 12:10 PM
Default RE: Carbs
heres a pic of the current setup and a vid of them running
http://smg.photobucket.com/albums/v5...t=MOV00009.flv
Old Oct 3, 2006 | 12:54 PM
doncollins's Avatar
Retired Administrator
Default RE: Carbs
I moved your post into the general tech so you may get an answer. The new member section is mostly for intros and hellos.
I personally don't know much about carbs, I'd if you need more fuel, I'd have to say jet kits.
Old Oct 3, 2006 | 01:40 PM
spdrmns's Avatar
Default RE: Carbs
i cant look at the pics from my work so whats your set up? how big is your motor.. (how many cc's) does the motor start and run like crap or does it not start at all? you gota be more specific with these kinda questions..
Old Oct 3, 2006 | 03:17 PM
Default RE: Carbs
it start and runs has decent power but after a while cuts out
i think this is due to the fuel pressure. i think if i rember right the cbr600 runs a very close pressure 2-3bar??
its beein used on a 1235cc micra engine but it only revs to about 5k
the power it was producing was very good oh and it sounds good too
Old Oct 3, 2006 | 08:02 PM
spdrmns's Avatar
Default RE: Carbs
yaup! its the fuel pressure! are you using the fuel pump from the car or the bike?!?!
Old Oct 4, 2006 | 05:14 AM
Default RE: Carbs
ORIGINAL: spdrmns
the car onew but i have a fuel pressure regulator (adjustable) and guage what figure do i need to set it to and is it possible to up jet them?
Old Oct 4, 2006 | 12:32 PM
spdrmns's Avatar
Default RE: Carbs
well i dont really know what amount of pressure you are supposed to have on those carbs but i can tell you that if its starting up and has good power, then your jet sizes are fine. your going to need to know the year of the carbs and find out on the internet what kind of pressure they have from the bike.. (im sure you probably already know that..lol..)
how long does the motor run for and then cut out? try putting the pressure on the lowest setting you can go. and see if it runs longer or stays running...
Old Oct 4, 2006 | 02:26 PM
Default RE: Carbs
it varies how long it runs for.
i dont know the year of the carbs but they look brand spankin new.
ive had it over pressurising and the fuel just leaks off the back of the carbs.
but it has serious power then ( burnt my clutch up :S)
Old Oct 4, 2006 | 06:44 PM
900RR Puzzle's Avatar
Default RE: Carbs
Wow, that's pretty cool!
Are you sure that the carbs or fuel system are not vapor locking, from heat? I've worked on cars all of my life, and from what you are describing, it sounds like something is getting hot and causin the motor to cut out, especially since the length of time varies. Try putting some form of heat sheild between the carbs and the head. Also check the ignition coil. See if it has spark at one of the plugs, after it cuts out.
Just a thought.
