brake lines
Old Aug 12, 2007 | 06:55 PM
cbr*sealik84's Avatar
Default brake lines
if anyone knows step by step how to bleed your front brake lines w/o a machine please help me
out
Old Aug 12, 2007 | 08:49 PM
knightslugger's Avatar
Default RE: brake lines
The same way you bleed brakes on a car... adjust the lever to full out, pump up the pressure, hold it, and open the bleeder without letting go of the lever, close the bleeder, let go of the lever, top up brake fluid if necessary, repeat.
Old Aug 12, 2007 | 11:30 PM
pacemaker's Avatar
I use a glass jar that has 1/4 fluid in it, I attach clear pvc tubing that fit snuggly over the bleeder valve, then do wot knightslugger suggested. Keep the tube immersed in the brake fluid & as you pump the brakes you can see the air bubbles as they move down the tube. It realtively easy, just make sure everything is clean & be methodical. make sure you don't over fill the resevoir, but top up as you go. as for the front brake, make sure you remove all excess fluid after you refit the cap, excess has a nasty habit of dripping out, and will destroy paint. Don't get it right the 1st time, just do it again till yer get it right.
Old Aug 13, 2007 | 09:44 AM
thanks guys i will try this today and let you know how easy it is....
thanks
Old Aug 14, 2007 | 09:34 AM
Tahoe SC's Avatar
bleeding without vac is fine, but if you're swapping lines and not just bleeding...then saev yourself tons of work and get the vac.
DRam
May 31, 2014 05:52 PM
cycle.tim
Jun 11, 2012 05:36 PM
f3racer
Jan 4, 2008 10:51 AM
traitorhound
Feb 20, 2006 07:30 PM
