brake light not working...help
I was taking my rear end apart last night to put on a eliminator kit, and after I was done, the brake light is no longer working. Anyone have any idea what's going on? This is on a 2002 f4i. I didn't even touch the brake light wiring. Does the brake not work when the bike is on a rear stand? The only wire I disconnected was for the license plate light. Thanks for the help in advance.
Check your brake light switch. I believe that they are adjustable, you may have bumped it enough to where it is not making a complete circuit. You can adjust it by loosening the backup nut and screwing the switch further toward or away from the brace it is mounted on. Hope this helps.
ORIGINAL: rEdLyNeR
the brake light switch(s) are located on the front brake lever ( underneath) and the rear brake light switch is behind the heelguards on the right side rider footpeg ( looks like a tampon with a rod sticking out the top)
ok...after taking a closer took, the brake light is actully on. Anyone know what that could be caused by?? Basically, the brake light is constantly on, when i'm not applying the brake.
ORIGINAL: sirlimpzalot
