brake cleaner in gas
Old Jan 27, 2014 | 08:13 AM
sephrin's Avatar
One question though there are 2 idle adjust screws on the carbs. How many turns out should those b for stock setting? Havent been able to find stuff on those
Old Jan 27, 2014 | 10:07 AM
CorruptFile's Avatar
June 2013 ROTM
What bike is it?
There are only a few different type of screws on the carbs.
- Mixture screws (1 for each carb)
- Sync screws (3)
- Idle adjust **** (1)
Not sure what screw you are talking about...
Old Jan 27, 2014 | 12:29 PM
sephrin's Avatar
There seems the be 2 screws on the throttle action. 1where the cables attach and one between the 2 left cylinders.
sephrin's Avatar
1998 cbr 600f3
Old Jan 27, 2014 | 02:35 PM
June 2013 ROTM
Not familiar with the f3 carbs, but they are all similar. Usually the screws between the carbs are for syncing. There is also a sync screw in between carbs 2 and 3, near where the throttle cables attach.
Maybe someone with an f3 can chime in if I'm wrong.
Old Jan 28, 2014 | 12:22 AM
June 2013 ROTM
I have a set of carbs out. Are you talking about the 3 screws you see here?
Old Jan 28, 2014 | 07:44 AM
sephrin's Avatar
Yes althought i could find a third one maybe i just over looked it
Old Jan 28, 2014 | 07:47 AM
sephrin's Avatar
Not the 3 on the rod part there is one on the part th throttl cable attaches to and between the 2 left hand side carbs on the spring action
Old Jan 28, 2014 | 07:49 AM
sephrin's Avatar
Also the screws on the side of the bowl cover. Those where th ones torqued all the way down. I opened each to 2 turns out
Old Jan 28, 2014 | 01:05 PM
There are 3 sync screws. The one between carbs 1 and 2 is a booger to see, but it's there. That adjusts carb #1 Then there is one between 2 and 3 that adjust #2 and another between 3 and 4 for #4. You initially set #3 with the idle adjustment ****, then adjust the others to match that.
The screws on the side of the float bowls are the drains. Those need to be closed.
The pilot screws, (D-shaped screws pointing straight down) need to be adjusted to the bike itself. Then service manual says to start each one at 1.5 turns out and adjust to max the RPM's then back each one down 50 RPMs.
Most people find that more often than not a setting of 2 turns out is about right.
