bike won't rev past 9k please help
Old May 6, 2006 | 09:57 PM
Montyburns's Avatar
Default bike won't rev past 9k please help
hey guys, im new to the forums and to riding. i picked up a 2000 CBR 600F4 with about 8k miles on it a little over a month ago. my problem is that the bike won't rev up past 9k rpm in any gear. i top at 115 because it won't go anymore. when i hit 9k i get this weird kind of ringing like sound and the bike starts to vibrate alot. i've asked some friends and some say it is a fuel problem, possibly dirty carb, or filters. others say it could be that my bike has a limiter on it or something like that. anyone know what the problem might be? any help is appreciated, thanks in advance.
Old May 6, 2006 | 10:44 PM
sprout's Avatar
Default RE: bike won't rev past 9k please help
Sounds like detonation. May be too lean.
Old May 6, 2006 | 11:05 PM
Montyburns's Avatar
if that is the problem, what could i do to fix it?
Old May 6, 2006 | 11:07 PM
shraz's Avatar
I would say clean the CARBS and if it doesnt work get a powercommander to fix the lean/rich mix
Old May 6, 2006 | 11:39 PM
crxgator's Avatar
correct me if im wrong, but i dont think he can get a power commander because it is Carbed...he would need to get it jetted...
Old May 7, 2006 | 06:59 AM
shraz's Avatar
true[:'(]
check the spark plugs
Old May 7, 2006 | 02:07 PM
slowpoke's Avatar
ORIGINAL: Montyburns
...hey guys, im new to the forums and to riding. i picked up a 2000 CBR 600F4 with about 8k miles on it a little over a month ago. my problem is that the bike won't rev up past 9k rpm in any gear. i top at 115 because it won't go anymore. when i hit 9k i get this weird kind of ringing like sound and the bike starts to vibrate alot...
Sounds like the ignition timing is retarded. If it was mine, I would get out my old school timing light and see if the ignition is advancing correctly. If the timing is correct, I would check the spark plugs, fuel pump, fuel filter, float level, and dirty piston/needle that is not rising all of the way out of the main jet.
Old May 7, 2006 | 07:05 PM
Montyburns's Avatar
thanks a bunch guys. i really appreciate the input.
Old May 8, 2006 | 12:59 AM
slowpoke's Avatar
Or maybe you filled up with regular gas and the engine is knocking.
Old May 8, 2006 | 09:48 AM
fishfryer527's Avatar
Or maybe advanced, is it hard starting? Maybe combustion chamber deposits that create hot spots and raise compression. Are there points or electronic ignition? Points suck. Could the coil be breaking down.
The truth is I have no idea, I just felt like replying to a post. Good luck. After you get it fixed, post the solution, i'd be interested.
