Bike will not continue to run
Hello all,
I am looking for further advice on a previous post I made regarding my 2001 cbr600f4i, (bike starts fine on the button but as soon as you release it the bike dies), I have disconnected the starter switch and checked for continuity etc...all is well there as is the starter relay.
I tried checking for shorts to earth by connecting my continuity tester to an earth on the bike then checking all wiring out of the switch.....am i mistaken thinking that the only wires that should show continuity are earths, (grounds)?
I had 3 of the 4 wires testing positive for continuity like this.
Am i completely off track here?
I will try and get a video up later but it's a case of the bikes starts on the starter button as normal then as the bikes running as soon as you release the starter button the bike cuts out...in other words as soon as the starter button is released and the starter motor stops the bike dies....no blown or blowing fuses, starter button checks out as does starter relay!!!
Cheers, SB
