bike sat with fuel in it for 2 years!
The gas may have started reacting with something in the fuel system, and it may have gummed up a bit from it, but I wouldn't think it would be enough to completely stall a fuel pump.
Sitting can do some odd things to electrics. I've seen solder points on relays actually crack from age.
I've also had issues with mice chewing wires (which is why I mentioned it). Hell, they chewed through my neutral switch wires, etc. a couple years ago on my CBR after just a couple months.
Just something to look at is all. But since it's at the shop, I guess none of this really matters. They'll figure it out.
yeah it's kinda academic now. I'm just saying the most likely cause isn't mechanical failure but varnish clogging things from sitting so long. A fuel pump dying after 900 miles and 2 years of sitting? Unlikely. Contacts corroding? Probably. Gummed fuel system? Probably - definitely.
My advice to the OP is if they state a major component needs to be replaced, question them. Really the shop shouldn't replace anything without permission and an estimate of costs
Easily? Just because you've had your carbs out 16,000 times (yes I've been counting ) doesn't mean he has. Not everyone is OK with sticking a screwdriver into something expensive to see what happens. I STILL hate taking my carbs apart, and I've done it 4 times. Next time I need it done, I WILL take it to a dealer, just because the money is worth the time it saves.
Reminds me of a bike my buddy pulled out from winter storage that would sputter out after starting. We sprayed a crapload of starter fluid into the intakes, started it and WOT, and it blasted a whole ****ing mouse nest out the pipe, along with a crapload of corn kernels.
No corn kernels, though.... I feel robbed.. lol..
(he zipties plastic bottles over his pipes now in the winter)
