Bike Problem plz help.
Hi everyone,
I have a 2003 600rr, I just got brand new fairings and alarm, I started put my fairings on then let my bike sit for two days, after I plugged the front cluster and the rest of the harness, so I will be able to “run my bike”, so after I turned the key, no fuel pump prim, got pissed so, let it sit for one more day, now my cluster will light up or do the “start up” that it normally does. This is where it gets confessing to me, I then for some reason unplugged the kill switch and start button, turn the key and dash lights and does it start up. Any Ideas? I checked the switches with a volt meter and both switches are good, I feel that when they are plugged they complete the circuit and there has to be a short, how can I find it, or could there be something else I am not thinking about. Thanks and all input will be helpful.
With new fairings it means that you had to move the Bank Angle Sensor to the new set. Check to be sure that it isn't installed upside-down. It is a common mistake that others have made.
giannisblest
Dec 4, 2011 03:33 PM
